Eagle trailer is from 2007, and has disc brakes. While putting back on my regular rim with new tire (got a flat towning due to cracked valve stem over 4th of july weekend) I noticed after I jacked up the trailer, the wheel was hard to turn. Then I noticed the brake pad was slightly applying pressure against the rotor. It would still spin, but not freely like I would have expected when the electric brakes aren't hooked up.
It is normal (im kinda new to all this) for the trailer brakes to be slightly engaged like this while the trailer is not hoooked up to vehicle? Or will this happen if I was applying the brakes as I cut power to the truck/trailer?
I didn't check the other wheels yet but plan to do so tonight.
My worry is that if this brake pad is slightly pressing against the rotor at all times, it is causing an unnecessary load while pulling the trailer with my truck.
Thanks for your responses!
Mike
Mike
