I have very faint spark coming from the coil(Mostly right after turning the key). when I turn the key I seem to get a couple of sparks then nothing. I have disconnected the Shift interrupt switch(Green/White wire) and the Tach ( Grey wire) from the coil with no change in results. Prior to replacing the coil I had absolutely no spark, I did have a spare coil I swapped out(New in Box). There is twelve volts at the positive terminal on the coil.
Any ideas would be helpful.
