I was out last weekend pulling a tube with my grandkids. 115 mer 2 stroke. Starting out I had to hit the gas pretty hard to avoid the tube going under. Once under way it pulled fine. I had a harness attached to transom clips, low on the boat. Maybe that was the problem. Anyways I did see some boats pulling tube with an inflatabe ball mounted between the boat and the tube. Just wondering why they use that? Do I need that?
Thank you.
Thank you.
