Ship of Fools
- Apr 29, 2008
- 4
I have an early 90's Force 9.9 that has been running like a champion until just recently.
Basically it is very difficult to start .... early this year it started and ran perfectly and then recently it wouldn't start and once it was started would only idle / troll with the choke on but at higher rpm's it worked great.
A year ago i had similar issues to what i am facing now and determined that the fuel line between the tank and motor needed to be replaced and after doing so the motor ran perfectly. This year i had the same issue and replaced the gas line from the fitting that the line from the hose connects to the fuel pump and it started better but still required the choke on.
A week later and that doesn't cut it either.
I replaced the line from the tank to the motor again.
In reading on here i saw many posts about it possibly being a fuel pump issue so i pulled the line from the pump off at the carb and when i turn it over i get spurts of gas on every pull which from what i have read means the fuel pump is ok.
Any thoughts?
Any thoughts?
