I need to add pull up cleats to a brand new boat. I will be adding the Accon marine 450-6 inch cleats. I need to drill two 7/8" holes per cleat. What is the best choice to use for drilling the holes? I was planning on using a regular hole saw, but at 7/8" I cant find one that I can run in reverse. At that size they are the screw on ones that just back themselves off in reverse.
How about a grit style hole saw? Are there ones that are arboured and would work in reverse?
Will a regular drill bit work fine? How about a forstner bit?
Once I drill the holes, what is the best way to chamfer the hole? The largest chamfer bit I can find is a 3/4" one. Will that work for a 7/8" hole or will it be to small?
Thanks
Thanks
