Re: Sevicing an un-siezed engine
I bought a boat with a seized engine. Previous owner ran boat engine out of water, Assuming I can un-seize the engine what other things should I service and/or inspect, replace on the engine and sterndrive? I plan on doing the normal tune-up stuff plus a compression test. This is a 5L mercruiser MCM 228 inboard built in 1983.
Ayuh,.... Welcome Aboard,... I wouldn't get overly Optimistic 'bout savin' a Severely over heated motor,...
Anyways,... I'd think
ALL of the rubber parts in the exhaust stream are fried to a crisp,...
Probably the flappers, 'n most likely the lower shift cable got melted,...
The Impeller is No doubt trashed, 'n it's housin' to probably,...
Head on up to the Adults Only section at the top of this forum,...
Lots, 'n lotsa Great learnin' in there,...
