I am considering buying a used boat with a mercruiser to remove for a boat that I currently have. I would be looking at boats from the late 1970s through the 1980s based on price, probably a 4 cylinder. The intended use would be in a aluminum fishing boat that is used in fresh water only.
Is there a advantage to staying new enough to have a Alpha one or are the pre-alphas just as good?
Is the 3.0 significantly better than a 2.5 liter engine?
Thanks
Thanks
