Hello,
I just bought my first boat. Picking it up this weekend! 2007 Rinker 192 w/ 44 hour.
The area of the lake that this will sit in is in open water and the wakes are pretty bad during the weekend. Therefore, instead of just tying it to the dock I want to put it on a lift.
But, I'm now poor after buying a boat and am trying to avoid buying a new lift.
I found this used Hewitt Cantilever lift for sale at another lake nearby. I could buy this and get it moved to our property for about $1700 (with a canopy)
I'm trying to find out a few things.
The Rinker 192 has a 22" draft with drive up. This lift has a 43" range of movement.
1) Can I use those existing cradles or should I build my own bunks using PT 2x6x12's wrapped in bunk carpeting? Can I get away with using them for a few weeks while I get those built?
2) I'm concerned that the height of the cradles is insufficient and the bottom of the hull will hit the cross member.
3) Can I leave a Cantilever lift at a 45 degree angle rather than straight up? The lake's level fluctuates (gradually usually) and I'd like to be able to keep the boat out of the water while still having some wiggle room.
4) The boat's dry weight is 2690lbs. 252lbs of fuel. Would this lift be sufficient? Seller says it's 3500# lift but I haven't seen that size lift made by Hewitt. Closest is 3600#
Thanks!
Brian
07 Rinker 192 4.3L TKS
Dutch Hollow Lake
Thanks!
Brian
Dutch Hollow Lake
