Re: 5.7L Vortec Swap
Without exact engine descripton's your job will be difficult.. I would check the timing what method was used to set the timing aka did you use a shunt to set the timing or this method..Is this is a delco est dist which you method did you use
Connect timing light to number 1 spark plug wire.
2. Start engine and run at 1300 rpm until it reaches normal operating temperature.
3. Stop engine and connect the scan tool or timing tool to the DLC connector on the EFI/
MPI wiring harness.
4. Start engine, allow rpm to stabilize.
NOTE: MEFI-1 models only, manually adjust remote control throttle lever to get 1200 engine
rpm.
NOTE: MEFI-2 and MEFI-3 models only, ECM will automatically adjust engine rpm to
approximately 1200 rpm when put in the service mode on a scan tool or when using the
timing tool.
5. Check ignition timing. If incorrect, rotate the distributor until timing is correct. Torque
clamping screw to 18 lb-ft (25 Nm).
6. Recheck ignition timing.
7. Disconnect scan tool or timing tool from DLC connector.
8. If required, return remote control throttle lever to idle position and shut off engine.
9. Restart engine, increase rpm to 1300 then return to idle position slowly. Ensure that
engine returns to idle rpm. Readjust throttle cable, if required.
10. Shut engine off.
Spark Plugs
So did you use a shunt.....or a timing tool? Below is a shunt
And the EFI timing tool...The shunt connects to the dist and the timing tool connects to the ecm or data link
The next step's would be to put a fuel pressure gauge on the fuel rail which should read a constant 28-35 lbs..they can be rented from most part stores.
Your new vortec intake is it a marine intake or a edelbrock type..and model number. And the new vortec head uses a long plug tip which is different from the older heads you had.
