I have a leak on my engine that I discovered recently. This leaks when it is hooked up to the water muffs. It is not a bad leak, it is a steady drip give or take.
There is oil in the bilge bay and I am not sure where this is coming from. The fuel pump was leaking oil around it, but I installed a new gasket and that seems to have fixed that. I cleaned out the bilge bay, but maybe I missed some. However I think it is still leaking oil from somewhere. However the water that drips from the flywheel cover is clear water so I am not sure on the oil. Anyways, I am thinking it may be the core plug, but I would think the leak would be heavier.
Thoughts?
Thoughts?
