Bought the boat a couple weeks ago. sounds good on the muffs. pulled lower unit to change impeller. while pulling unit I couldnt get the shift rod unhooked. getting a little rough with the linkaged oil started to run down the side of the motor?? not sure where that came from!? so after getting that job put back together..started it up on muffs and it sounded ok...alittle miss here and there. but we had good water flow and the gears worked..so we hit the lake.
right off the trailer i had a hard time starting it. smelled flooded, so i unhook the gas line till it finally fired up. hooked line back up and away we go...way under powered! chuggin along wont stay running at idle. pulled the top plug wire while running and no differance..switched out the bottom cylinder plug and wire..still nothing out of top cylinder. checked for spark..good in both plugs.
Going to stop and get a compression tester after work. might try and spray some fuel into the carb and see if the carb is the problem.
as u can see..not a good start to this new purchase!! lol
oh and whats the difference between the usual plugs that u can gap and the other flat ones that u see in most marine motors. I went to buy new plugs and the ones they have in the motor now are flat ends and the ones in the book are like car plugs? wonder which ones are supposed to be in it??
