Hi guys,I currently have a 18.5 foot Steury v-518 with a 165 i6,boat weighs around 2100 and and the gearing is 1.65. The prop i currently run is a 14.25 x19p 3blade,,the prop has good top end ,but not much in the way of hole shot and has trouble maintaining in corners,also i do alot of tubing and skiing.At WOT with 4 people in it i get around 3800 rpms which seems a little low. When i got the boat it had the stock 15.5 x15p prop on it but was pretty bad shape so i bought 19p prop mentioned earlier. How much if any top end will i loose going back to the 15.5x 15p prop or would i be better to go with a 15.5x 17p? or 16p? I know if i stayed with current dia and went with less pitch the rpm would shoot up and i would prob loose some top end but what will the effects of bigger diam and less pitch be? will i loose a little top end and gain alot of holeshot and better cruise or will top end stay close and gain handling and holeshot and stability.Let me know your experiance.You guys are far better versed in the right prop selection than i am,,,thanks for any input.I have read several articles but cant seem to draw the right conclusion. Matt
