today i pulled off my dash so i can look at the wires better, it looks like somone in the past replaced the ignition switch and it may have not been the orignal switch, i say that because the switch was pushing the circuit breaker over. and the harnes that went from the switch to the end/begining (depends on how you look at it) of the harness that went to everything else and the motor, had the black and blue wires cut on the ignition switch side.
i was looking at the wiring diagram and i do not see any blue wire or black wire that goes off the switch. also when i was looking at the back of the guage cluster i seen the black and purple wire that connects them all together and it shows up on the diagram, however there is a blue one as well that connects to them all and that does not show up on the wiring diagram. there are a few single wires mixed in but i see those on the diagram,
so i guess my question is what is the blue wires that also connects all the guages, and can anyone link what the actual ignition switch should look like and/or describe where thos two (black and blue) wires should be connected on the switch.
thanks
oh yea the boat is a 89 baretta with volvo aq131d. if you need a picture of what im talking about lemme know and ill go take one, had to stop for now started to rain on me this morning
thanks
