shankforce
- Sep 9, 2008
- 114
First a little info. I am running a 97 Mercury 200 HP offshore series 2 stroke carbed. Oil is mixed direct removed the injector system. Very little hours on the motor. Brand new plugs and brand new gas. The fuel bulb sometimes even before I run it seems to not get very hard but it runs well at idle. When I put the hammer down it gets on plane than boggs down to idle speed or shuts off completely when it does this the fuel bulb collaps flat and seem to barely suck fuel. I run the motor on a 1998 campion explorer 622 wa. I do not know where the fuel tank anti siphon valve is. I never had this issue before. I tried a differnt fuel bulb same effect they both seemed to work but are both old and could both be bad who knows.
