Ghotiyfish
- Jul 7, 2013
- 2
Hello,
Boat: 1972 Arrowglass Tarpon Mark IV.
I have been reading a lot of threads on transom and stringer repair on these forums.
I am repairing my grandfathers boat. He bought it new in 1972. The transom is completely rotten and I suspect the stringers are also rotten. The transom was replaced once in the late 80s or so. After I replace the transom I will tackle the stringers.
For replacing the transom I plan to cut the fiberglass on the outside of the boat all the way to the edge of the boat and when putting new fiberglass on wrap it around the sides and bottom about 6 inches. There is a crack on the bottom where it meets the transom that I will have to repair. This is why I plan to wrap the fiberglass around the sides and bottom. Will this create a problem or is it acceptable. The transom was made of two 5/8" and one 1/4 plywood. I plan to replace it with two 3/4" marine plywood pieces.
I should have the top off the boat by the end of next weekend. I am going to build a stand from 2X4 to put it on.
Rotten transom
Crack on bottom at transom
Transom
Top removal
Rotten transom
Transom
Top removal
