93 mercruiser 3.0 digital electronic ignition
arg3pirates
No power from the coil to the distributer, all 4 wires going into coil lights up test light with ignition on (no fire). Can this be due to anything other than the coil?
arg3pirates
Re: 93 mercruiser 3.0 digital electronic ignition
Thanks for the file. As I looked at it I realized it is the wrong one. My engine coil has 2 wires purple and grey in one male plug plugging into the top spot on the coil then another two wire male plugin going in under that one pink and grey. Then the distributer connect.
With the key turned over there is power into the coil on all 4 wires but nothing coming off the coil to the distributer even when cranking.I am stumped hope you can help. Want to take the family to the lake.
