I'm currently breaking in a rebuilt motor and when pulling the plugs after todays run I found this. In the first picture, the plugs are lined up left to right for cylinders 1-4 respectively. Cylinder 2 is showing a clean white color around the outside, does this indicate a leaking head gasket? None of the plugs look the same, but the others are a least a light or dark brown color.
The motor is also making a very noticable rattle noise at low and high RPM. Sounds like it's coming from inside the powerhead.
This motor was bought from Outboard Exchange out of Waterford CT, and I would NEVER recommend buying a remanufactured motor from them.
