Engine runs great but overheats after idling for just a few minutes. The intake hose has good water flow, like a garden hose, from the lower unit. There is no thermostat in, so it's like the thermostat is always open. Have tested both the exhaust manifold and engine block for obstructions with a garden hose, and there is good flow with no back pressure. The temperature gauge has indicated as high as 210. Checking the water hoses with my hand reveals that they are very hot, too hot to touch, so the temperature sensor is correct in my opinion.
The water drains out though a flexible boot at the lower unit pivot point rather than through the center of the prop. I think the boot is torn, but the water flows freely out of it, without any pressure, so I don't think this would be affecting the engine's temperature.
I'm not sure how to proceed with troubleshooting. I am considering tearing into the engine's water pump, but I am not hopeful that I will find a solution here. There are no unusual noises, leaks, etc. Like I said, it runs great. So why is it overheating? The last time we ran this boat, it ran great. I would really appreciate any help or guidance.
David
David
