CoachRobJ
- Sep 6, 2012
- 3
I purchased an older Evinrude 70hp 2 stroke with my 16' ft Blue Water last August. When I go to start it, it will run for 10 seconds or so and stop. It won't restart after that.
1. The first time I start it, I use the choke by pushing the key in and holding it down while the key is turned.
2. I use the primer bulb prior to starting it.
3. After it runs for the 10 seconds or so, I try restarting and notice fuel comes out of the top carburetor.
4. It has newer plugs and are properly gapped.
5. It was running last fall just fine.
6. 50:1 fuel mixture
Please help. I'm not real familiar with 2 stroke engines.
Unfortunately the tag that provides its serial number, yr and model was missing when I bought it.
