saltydogjeff
- May 12, 2013
- 145
So, getting my boat started, I have been through all the starting points for this engine to run. Well, apparently not because it is not running. So, I have gotten to the point where I think there is the possibility of two issues. I was trying to start it today, and would put carb cleaner into the carb. the motor would only ignite for a couple of seconds and then stop. I know there is fuel pressure at the carburetor because when I loosened the connection fuel squirted out. Since this is a new carb, is there anything that needs to be fine tuned? I saw a flat head brass connection on the bottom of the carburetor that I've tried screwing inwards and outwards. Is this just patience and continual starting to get this thing going? I've probably turned the engine over 30 times. I'm getting worried for my batteries.
Edit: I think the second issue could be on the ignition side. But obviously if it runs for the 2 seconds from the carb cleaner, then I don't think it is a spark problem.
