pcrussell50
- Sep 21, 2008
- 296
overheat alarm sounds at mid power, not at idle, and little or not at all at high rpm...
took the heads off and the passages are clean and the flow diverters are in place an in good shape. will take the foot off and re-check the water pump, but it's new with only a handful of hours on it and the telltale is strong, as is the flow out the two water-exhaust holes under the powerhead tray.
so i'm afraid i'll have to do the knucklebusting job of replacing the thermostat on a bubbleback. yuck.
anyhow, for those who have done this job before, should i just order every part that sits under the thermostat housing including the spring?
or just the thermostat, and gaskets?
of course, any tips on making this job easier are welcome. i build my own race car engines, so i'm pretty comfortable with tools, but i'm no better at working in tight spaces than anybody else.
-peter
-peter
