So we have a 30 HP carb that just doesn't like to start. The only way I can get it to start is to flip the throttle open manually while I have someone turn it over. At that point it will only run as long as I keep on the throttle or run it in gear needs throttle to stay running. I will mention I put three brand new carbs from mercury on it and have tried the lync and sync procedure.
