Liquid_force
- May 7, 2003
- 318
Hey all,<br /><br />Prepping for a flooring job in the next couple weeks. Would like to put a bit more info together.<br /><br />-- The only marine carpet I found at Lowe's/Home Depot is 12 oz. and 6' wide. I can't access the boat right now to get a measurment on the floor, but the beam is 7'3" and given the slope of the sides I don't believe the floor is over 6' wide. Think the 6' carpet will get it done?<br /><br />Fiberglass - As a whole I believe the floor is in decent shape. It's not mushy anywhere, but it does flex in a couple places. I would like to put a couple layers of fiberglass down in these spots. I'm thinking 2-4 layers, no more than 2'x 2'.<br />The only other glass work I'm planning is around the ski storage opening. I'd like to reduce the size of the opening slightly because several of the screws in the aluminum trim have stripped the wood in the floor, and because the lid is really loose fitting in the opening anyway. I'm probably going to do 2 or 3 layers a few inches outside the circumference and then wrapping down around the edge.<br /><br />The only fiberglass product I've used personally is the bondo stuff at the car parts stores and the bondo polyester resin. Being that I need 4 yds or so I though I'd order glass and resin from us composites.<br />-- My problem is I don't know what weight the bondo stuff is and what weight I need to order from US composites, and I'm not sure what type of resin would work best.<br /><br />I'm also considering slapping down a layer of some sort of sealer, maybe like the stuff used in the bilge, just as a precaution since I'll have the floor up anyway.<br />Good idea? Product ideas?<br />Waste of time/money?<br /><br />Sorry it got so long. Hope someone can help me out.<br /><br />TIA
