Evinrude 70 hp fuel mix
wrmdunker
Re: Evinrude 70 hp fuel mix
You will reap many rewards if you use good mix oil like Evinrude XD30. Stay away from the cheaper big box store brands. And add an ethanol fuel theatment to every tank unless you know you are using marina ethanol free gas.
JB
XD30 will cost more. XD30 will smoke less and carbon less.
Use TC-W3 oil. SuperTech oil from Walmart is preferred by many. Cost of advertising and merchandising is avoided.
Buttonc22
Okay thanks i am kind of looking at the Walmart oil just for the cost and easy access
Buttonc22
Any thoughts about Evinrude's synthetic 2 stroke found at Walmart?
