I have 1988 Johnson vro. It will run and idle fine all day hooked up to the hose in the driveway. First time I put it in the water it ran real ruff bogged down and would stall. I smelled gas and saw one of the carbs was flooding up so I got carb kits and did the one that was flooding. I put back in the water and it ran great for about a 1/4 mile or so then started to bog down and stalled. After I finally got it started it would only run at a crawl back to the dock. So I did the other two carbs thinking it couldn't hurt and also changed the fuel filter. I put it back in the water for another try and it idled fine in the water but when I would lock the throttle lever down so I could put it in gear it would stall kept trying it kept stalling. I also checked compression in all 3 cylinders they were all around 100 and checked the spark it had good spark. Any input would be greatly appreciated.
