55 evinrude 7.5 not pumping water after overhaul
14 ftr
I just got my fleetwin back together today and it started up fine but even though i had both water intakes submerged it wouldnt pump is there a way to prime it or something? Also if i end up having to pull the powerhead again do i need to get another new base gasket or can i reuse the one i just put in? What could i have done wrong that would have caused this? :facepalm:
ddwilson
Re: 55 evinrude 7.5 not pumping water after overhaul
the water needs to be pretty high up (3-4" is not too much) for it to prime if it is just above the intake some times is not enough for it to prime. I found that on the 58 10hp I just worked over.
nwcove
you need to have the impeller submerged. they wont self prime.
14 ftr
Ok thanks ill try it in more water and let you know what happens.
HighTrim
If the issue is not the water level, did you forget the key? Water line not pinched in grommet? Intake free of debris? housing/plate not worn?
If you don't tear/damage the gasket you can reuse it.
14 ftr
Ok lesson learned it just needed to be in more water to prime thanks for the help it runs like the day it was made now:)
