Hi All,
There is a shaft pin that connects the piston rod to the swivel bracket on my 1986 75hp mariner outboard and I can not seem to get it free. Any Ideas would be greatly appreciated!
I have here the ********** diagram:
shaft pin is #22 and it does move freely as far as tilt and trimming it up and down just can not figure out how to remove it.
http://www.**********/parts/search/Merc/Mariner/1986/7075726/POWER TRIM COMPONENTS/parts.html
There is a Pin in the center and you should be able to tap that threw and threw thus releasing the shaft which can than be tapped out. sometimes it may be stuck and seized I managed to apply a little heat and she broke free
