Re: Air Compressor Specs.
a good gravity feed HVLP gun the kind with the cup on top is gonna use alot less air than the "old style" suction type guns the kind with the cup on the bottom.<br /><br />Body shop type air tools use more air, by the nature in which they are used, when in use, they tend to be on more than they are off. <br /><br />I would buy the biggest one I could afford, make sure its a belt driven two stage pump with at least a 220v 6.5hp motor and a 30 gallon tank of a name brand type. CFM specs can differ by a wide margin, depending on how the manufacturer measures it. You also need to think about how much your going to use it, look at the duty cycle rating, one with a 50% duty cycle needs to "rest" an equal time as its working, one with a 100%duty cycle need no "rest" at all meaning and can runn constantly without burning up. Like upinsmoke said, Do not buy a direct drive "oiless" compressor. They are made for the homeowner that wants to pump up a tire once in a while, or maybe run an impact wrench on an infrequent basis, they don't last, and the term extremely noisy is an understatment.<br /><br />also there is "self leveling" paint out there that can be rolled or brushed on. The boats I have saw done this way ended up rivaling ones that were spray painted, in other words they looked real good when finished. And you wont have to buy a compressor.<br /><br />A good compressor thats gonna do what you want it to do is gonna set ya back 500-700 buck on the low end. (at least for one thats gonna last a long time) There are cheaper ones but they arent that good. Unless your not gonna use the hell out of it. But if you are get a good one <br /><br />by the way how bout some pics of that boat??
