Hi
I have a seadoo spi and it will not turn off after starting. It start fine as long as you have the safety lanyard on. But when you remove it, it will not stop, not even if you press the stop button. I have checked the stop button and lanyard are both connected together as it will not start with out the lanyard on , or if you press the stop button. Can any one help?
Thanks david
Thanks david
