I am new to boating so need some help. I have a pontoon with a 1987 90 hp motor, When driving at 2800-3000 rpm the engine runs fine, any rpm's higher then that the engine sputters and stalls. It will start right back up after a couple of mintues and run good until it gets pased those rpm's, It acts like it is running out of fuel, tank has plenty of gas, the buld is not holding pressure, will that cause this problem? Thanks
