I have an electric/alcohol stove in my boat. When plugged in to shore power (110V), the electric elements of the stove operate perfectly. When I switch from shore power to my Westerbeke generator, I get an indication of "Reversed Polarity" when I switch on the "Electric Stove" switch on the breaker panel. Based on the Reversed Polarity warning, I have never actually turned on the stove for electric use off the GenSet power as I am concerned about damage, shock, or worse.
Might I get an opinion from the forum on why this would occur on the GenSet but not when plugged in to shore power? All other systems (A/C, Ice Maker, Hot Water Heater, 110V side of Fridge) operate normally with both shore power and GenSet power and no reversed polarity indicator. Once again, only the electric stove on GenSet power indicates this problem. Is the issue in the stove wiring? If so, why would it indicate reversed polarity only when GenSet is providing the power?
Thanks in advance for your expertise and guidance.
Verboatin
Verboatin
