What causes the alarm to give the short beep when the ignition switch is turned to ON? I know the alarm sounds as the tan wire becomes ground when the temperature switch gets hot. I can't find anything in the wiring diagrams of the engine or remote control that shows how the alarm gets the momentary ground to sound when the switch is turned ON. My issue is the new to me '95 112 will give a steady alarm when switched ON, sometimes. It will stop on its own sometimes after 10 or 15 secs., sometimes it will stay on for several minutes. Once it goes off after the initial turn-on, it acts normally for the rest of the boating trip, with multiple stop / start cycles. I have tried ohming the engine and control side cables and can't find any shorts, tan wire to ground. The temp switches read open to ground. I've bent, twisted, pulled the cables and done everything I can think of to try to make it happen, but can't cause it. It just does it when it feels like it. I'm thinking if I know what causes the short beep at turn-on, it might point me in the right direction. Maybe the horn itself, ignition switch, is the power pack somehow involved in the alarm at turn-on? This motor has no VRO, only the overheat alarm, very basic. I'm stumped.
