Re: no click from primer solenoid?
You should only hear a click if the key is turned to the start position as well. If you did that and can't get the electrical primer solenoid to work, you can remove the wire going to it and jumper a wire from your battery and just touch that jumper-wire to the wire on the solenoid to see if it is working. If it doesn't work then, you may have a bad ground or a defective solenoid... If you own a DVM, VOM or any type volt/ohm meter, and know how to use one, you can check it out real easy... Let us know the results...
