I replaced the tilt motor on my buds Jonny 225 1992 j225txner all went well swapping to new motor, took old motor apart looked real bad inside, replaced with new motor, 4 bolts 1 green 1 blue wire so engine was in about the half way up position, I put fluid in the plastic screw cap on strbd side, not much seem to go in. tilt motor runs but nothing seems to be moving up and down, a couple times while pushing the buttons the smaller little two secondary rams made a bit ov movement but thats about it. so is there a lock pin/ lever/ latch etc. that I am overlooking. or did I put the fluid in wrong place or just do everything incorrectly. I have no manual for this model and neither does the owner. any and all help would be great we want so bad to go out this weekend! thanks
