Hi I Have a Mercruiser 5.0 2bbl carbureted, I took off the carb to have it rebuilt 2 weeks ago, I thought I had covered the intake manifold quite well, however my cover moved, and rain water dripped into the manifold. I got what I could get out of it siphoning it out with an eighth inch flexible hose that I pushed all through and around every bend i could until I could not get any more out. The motor has not been started yet this year and it was winterized with fogging oil on the last shut off. I am wondering what I should do from this point. Should I remove the intake manifold before I turn it over, could water have filled the cylinders? There is no water in the oil, at least on the dip stick. Any help is appreciated
