Looking at replacement carb filters on the net I see that there is an option for a filter with a built in check valve to stop the bowl from draining between uses, is this suitable for marine use or will it cause too much restriction at the higher RPM that marine engines run at? My engine does seem to suffer from carb bowl emptying which causes hard starting if its been sitting for any more than a day or so.
