twistable_deer
- Jul 3, 2013
- 5
hello, i have a 2006 3.0 liter mercury engine that is stalling out. Now I just pulled the boat out the storage and i tired to start it up, it took a couple if seconds and fired up but it had really rough idle and it did not get better as it warmed up (it sounded like a diesel engine) so i shut it off and took the carb out to clean it then bolted it back in and fired up (again it took a couple of seconds but quicker then before) it fired up and it still had a rough idle but not as bad as before. it eventually smoothed out and when i gave it gas (about 2000 rpm) it wouldn't idle after that. to fire it up again i had to press my throttle all the way down and back up which adds more gas and it fired up for a few sec then died. The only way it would stay running if it was above 3000 rpm. This happened last year but not as bad, once i got it out on the water it ran fine and only stalled a couple of times but fired up again. Now i am thinking about taking it to a mechanic to get it tuned up but i just want to see if you guys have any suggestions on what could be the problem before i spend money at a mechanic. Oh and i forgot to mention that all of my problems are happening on the ground.
Thanks
Thanks
