I guess it would depend on how severe the wear is. The diameter change can be adjusted for just as you would adjust for initial contact.I don't have that engine but I have inverted the roller on one of my engines. When I did this it would contact the cam on an unused part of the roller. It's worth a try.
Heat shrink tubing isn't going to make the roller round again and it would change the diameter of the roller.
14 bucks at marineengine item 22 carb group.
Holy cats. If I had one, I'd give it to you. I'd even make you one from Delrin for less than that. It would never wear out.
