simcole
- Mar 31, 2013
- 35
Hey again everyone,
I've spent the past several days using the search feature of this forum and reading about DIY upholstry projects. I saw a couple examples of some machines that people started with and are using, and most of what I gathered is that consew was a great machine but out of my budget range currently. This fall/winter I plan on recovering my boat seats that are starting to pop seams. I believe most of my seams will be hidden, but I'm not 100% sure on that. Here is a picture of my boat:
On with the questions:
Can I purchase a 1950-1960's model singer and buy the addon "walking foot"? Will that be sufficient to get my boat done? Is it good enough to take on 1 other persons boat and use the profits from that to buy a good machine? Here is the examples of the singer addon walking foot.
Which of these machines will work?
Number 1
Number 2
Most of these seem to only hold a #18 needle. Is that ok? V92 thread too big for this or do I need V64?
I saw several people say wrapping the foam in plastic helps with moisture which is currently a pain when I sit down on a seam and get wet butt. Do you leave the bottom side of the foam not wrapped so air has a place to escape? Do people just use trash bags or what?
See the curves in my seat patterns? Do I need a ton of yardage to make the curves?
TLR:
Help me pick a machine to recover my seats this fall and I can probably figure out the rest.
Number 1
Number 2
TLR:
