lx.crowell
- Jul 12, 2012
- 40
I have a 1963 75 hp johnson with electric shift. the motor has been running a little rough during idle and when you go to plane it out it seems to run on three cylinders and then will smooth out and run smoothly but still won't have all of the top end power that it used to have. When i pull the plugs to do a read on them they read clean and good so i am very confused right now. Also what plugs should you run in that motor as i am currently running j6c's in it. Any help would be greatly appreciated, thank you.
