mwe-maxxowner
Master Chief Petty Officer
- Jun 20, 2012
- 825
I'm in the process of reinstalling my outdrive and motor. I need the transom gasket and the two anode bolts on the bottom of the gimbal housing. In an earlier thread I was given a part number for the transom gasket, but when I enter it into the parts search I don't get anything. When I search for a transom gasket, it only shows one for the Gen two. I have an alpha one Gen one 1.86 ratio.
My anode bolts twisted in two. When I search iboats, the search yields the acorn caps, but I need the whole bolt and everything. I can't find info about them in old threads so far. If I can't find anything I guess I could find a bolt that fills the hole and then add an anode and ground it to the gimbal housing?
