joysticks
- Sep 27, 2011
- 85
Hi, It's me again, Joysticks, previously had another question (which was answered very promptly tyvm) but need some advice:
I am at the point that I am almost done with replacing the bellows, having a little problem putting sleeve in u-joint bellows but got some tips from the forums, My question is-do I need to put more grease on/in the u-joint while I have the outdrive open, (I know I have to replace the gear lube), also is there a glue that I should use on the gasket.
(I am sure I will have more questions as I progress)
Thanks, Joyce
Thanks, Joyce
