propmonster
- Jun 11, 2012
- 16
Hope I'ts ok for me to post this in here, my boat is actually a Four Winns fling with OMC jet drive, but everything I have researched says the motor isthe same as Johnson-Evenrude and I figured I'd get better response here. So anyways I'll try and keep this as simple as possible.
Boat sat for 2 years, start for first time, starts real hard but get it going and after a little warm up time she runs pretty good. I play around for about 5 minutes, spin the boat around, drive lifts out of water, engine free revs for a second and just stops! I let it set for a second, turn the key and it fires up, put it in gear start moving forward and the warning buzzer goes off, overheated?? So I idle for a minute and the buzzer stops, try to accelerate and it will only go about 1/3 throttle and bog out, so I limp it back to shore having to go back to idle a couple times to kill the buzzer. I bring the boat home, do a compression test and get;
115 122
110 105
Looking from back of motor.
Pull heads and # 1 (with most compression) has some minor scuffs, all others look great.
Install new head gaskets, new compression test;
106 122
105 106
try to get it started and it tries and tries but will only fire for about 5 seconds then quits, sometimes with a cough, or backfire, acts like it isn't getting fuel so I put some pre mix in spayer, remove airbox and spray directly into carbs when trying to start, doesn't really help, so go other direction and no spray no primer, won't fire at all.
Here's were it gets interesting, my kid says lets check spark, so I pull #1 plug, set on head and tell him to hit the key, the damn thing fires right up and runs!!! Put it back in and same ole crap, fire's but won't start. So I try pulling another plug, and sure enough it starts and runs. I don't get it, why will it only run if I remove a plug, any plug????
Please Help!!
115 122
110 105
106 122
105 106
Please Help!!
