Just had new carbs rebuilt and I am having problems starting the motor. When I pump the ball it does not get hard. I can hear gas in the bulb but I was told to pump the ball until hard, the put the key in the ignition and push in to choke it. I did manange to get it going and it seems to run fine except when I pull a tube. With a tube in tow it stalls out when I hit it out of the hole. Without the tube it comes out of the tube just fine and gets up on step easily.
What do you think the problem is?
Thank you.
Thank you.
