First let me state I only have a 2-way switch on my dash. Just want to be sure I'm clear after bouncing around the forums. The Sahara 500 is an automatic bilge with three wires. This is what I think I need to do:
Black wire to negative terminal
Brown/White/Tan to two way manual switch on dash
Brown wire to positive terminal with fuse holder near the battery.
I also assume if my two way switch is in the off mode, that the auto feature will still work since a wire runs directly to the battery (through a fuse).
