I have a 1982 15 HP motor that was sitting for a few years with no fuel in the lines (previous owner ran fuel dry to store it) I got new fuel it started right up and seemed to run OK. I got to the lake and put the boat in the water and it started right up and idles fine when i put it into gear it runs then i try to throttle up and it barely moves and faster..I am going to clean out the Carburetor and change out the water pump when the parts come in. But does anyone have any other suggestions I might be missing. also i want to change out the gear oil in the lower unit what kind should I use.. THANKS!!!
