Hello all, thanks for the wealth of info on the site. I have a 78 merc470. serial # on drive is 5188062 Got it out this year and found prop was hitting trim tab/would not rotate. Long story short my lower unit froze and pushed the prop shaft support out, also took the threads out of the case making it non-rebuildable. I have since found a real nice used unit off of an 84 boat. I believe it is the same unit with a slightly different ratio.
1st question- What is my original ratio and will I notice a difference if my new unit is 1.98? The ratio on my original unit is not stamped in the case and a search yields different results. If the unit will work I plan on playing with different props starting with a 21 (17.5 foot boat, rally175 by cruisers) until I find the best setup.
#2-- The yoke on the upper shaft(engine to outdrive) was longer on the new unit than the old. I swapped the yoke end of the shafts to keep the same length on my new unit. Will this work or is this a sign that I bought the wrong part?
My new (used) unit looks really nice with nice original paint. Seller recommended installing and using as is with no new seals or water pump. He claimed that the squeaky noise when turning the shaft was a sign of a good tight pump, that sound like bs? One last thing, the new unit says 3.0 on it and the 470 is a 3.7, does that matter? Thanks in advance for any and all info.
