Kirks World
- Jul 1, 2013
- 10
Serial # 4012246141. During operation, after operating the boat at elevated RPM's, when the throttle is returned to idle or neutral I get an intermittent audible warning (about every five seconds). It does not do it every time. When it does, the Temp(157), Oil Press(38), and Batt Voltages (13.8) show normal on both the digital and the analog gauges. Twice the boat has gone into safe mode (all gauges read normal) . Turned the key off and restarted the engine, no alarm and operated normally each time. 250 Hrs on the engine. Spark plugs, Exhaust manifolds and risers both replaced in April 2013( less than 20 hours on new manifolds). Suggestions?
