I have a 97 stingray and only burn half the 40 gallon tank due to poor placement of pick up tube in tank so my idea is to add a fuel tank. It will be a 20 gal external tank Ive had for a while. Im going to have a hose spout welded at the bottom of external tank. I want to hook that into the fill on the original tank and hook the fill tube from boat to the external tank fill. Im going to cap off vent from original tank and use the vent on the external tank. I need feedback on this I want to make sure this sounds correct dealing with fuel and I know it can be dangerous. Also have another concern this is a 4.3 I/O and the pump sits right above the original tank bolts to side of block. When I fill the external being as its going to be bolted to floor and a lot higher than original tank do I need to worry about the pressure and the fuel being higher than the pump it going pass the pump doing damage to engine. Im sure Im not the only one came up with this idea and I need any suggestions or help everyone can give me. Thank You
