Hello I'm new to I boats. I have a 1992 Galaxy W/A with a 4.3lx v6 with a 4 brl carb. last fall had a problem with it just shutting down. After replacing fuel filter, coil, & standing on my head for hours I found the terminal board at the neutral safety switch bolts had backed out after I tightened the bolts back the thing started and ran fine until. I cleaned the Hull under the motor and the rest of the boat it set for Two weeks it just would not start. I Replaced the coil and plugs it started and ran fine on the trailer put it in the water started to head out I could feel it miss turned around to head back to the doc started to lose power then started popping through the carburetor I could run it around 2200 RPM's with no problem I'm at your mercy please help family would like to go out on the 4th of July I think it may be the sensor in the distributor.
